Product Name | Single Cabin Vacuum Machine MTQ70 |
External Dimension (width) | 28.3 |
External Dimension (height) | 39.5 |
External Dimension (length) | 38.8 |
Voltage (V/Hz) | AC 380/50 220/50 110/60 |
Power (W) | 1500 |
Sealing Power (W) | 1000 |
Ultimate Vacuum Pressure (Kpa) | 1 |
Sealing Width (inch) | 0.39 |
Chamber Dimension (LxWxH) (inch) | 35.6x23.8x7.4 |
Vacuum Pump capacity (m3/h) | 2x20 |
Material for Vacuum Chamber | SUS304 |
Net Weight (lb) | Approx.445.333 |
Category | Vacuum Machine |
Features
1. The products after packing can be prevented from oxidation, going mould, insects or getting damp, thus can be kept fresh for long storage.
2. The machine is deep in chamber size, which facilitates packing big products.
3. The sealing assemblies lie like L, so users can choose either long or short side for bag sealing.
4. Transparent organic glass lid enables users to well monitor the whole work process.
5. It adopts relay control, while PCB control is as optional.
6. The vacuum chamber could be added with inclined stainless steel platen for products with liquid.
7. The vacuum chamber could be added with PP insert plate for products with different heights to improve the vacuum efficiency.
8. It could be equipped with dust filter for the products similar to powder.
Note: if the function of gas flushing is required, the machine model is MTQ 70 series whose technical parameter is similar to MTQ 70 series.
