shrink film machines, vacuum machines, seal vacuum machines and packaging films
Product Name
Single Cabin Vacuum Machine MTQ40
External Dimension (width)
22.4
External Dimension (height)
19.8
External Dimension (length)
19.1
Voltage (V/Hz)
AC 380/50 220/50 110/60
Power (W)
750
Sealing Power (W)
450
Ultimate Vacuum Pressure (Kpa)
1
Sealing Width (inch)
0.39
Chamber Dimension (LxWxH) (inch)
15.9x17.9x7.4
Vacuum Pump capacity (m3/h)
20
Material for Vacuum Chamber
SUS304
Net Weight (lb)
Approx.176.3
Vacuum Machine
Tooltip Content
Features
  • 1. The products after packing can be prevented from oxidation, going mould, insects or getting damp, thus can be kept fresh for long storage.
  • 2. Table style vacuum packing machine is compact in structure, easy to operate, can apply in space limited working place.
  • 3. The machine is deep in chamber size, which facilitates packing big products.
  • 4. Transparent organic glass lid enables users to well monitor the whole work process.
  • 5. The vacuum chamber could be added with PP insert plate for products with different heights to improve the vacuum efficiency.
Note: if the function of gas flushing is required, the machine model is MTQ 40 series whose technical parameter is similar to MTQ 40 series.
